Solved lost SEF urls after installing Admin Tools Professional
10 years 9 months ago - 10 years 9 months ago #173199 by colhiogroup
Kunena is now sending all my forum categories to a .../component/kunena/... URL and a 404 page. I haven't made any changes to my site other than installing Admin Tools Professional. I've lost my SEF urls (they are enabled in Joomla and in Kunena). Using Joomla 3.4.8 and Kunena 4.0.10, and Admin Tools changed htaccess.txt to .htaccess. Any suggestions are much appreciated!
EDIT TO ADD: I've tried disabling the Admin Tools plugin and replacing .htaccess with the standard Joomla .htaccess file, and still getting the nonSEF urls/404 message.
Here's my report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : iReview3 | author: ClickFWD LLC | version: 3.3.0 | creationdate: June 2015
Kunena default template details : NTS KMaterial | author: Nice Theme Store | version: 4.0.0 | creationdate: 2015-11-18
Kunena version detailed: Kunena 4.0.10 | 2016-02-18 [ Villavicencio ]
Third-party components: UddeIM 3.6
Plugins: None
Modules: Kunena Latest 3.1.2.1 | Kunena Stats 3.1.2 | Kunena Search 3.1.2
Last edit: 10 years 9 months ago by colhiogroup.
10 years 9 months ago - 10 years 9 months ago #173202 by rich
Try the following (I hope that it helps):
1. Select in the kunena SEO configuration "Direct Component Access = Yes"
2. Repair your kunena menu items
You've 17 kunena menu items, but only 3 are correctly ( see here ). Only if no 404 errors occur, select again "Direct Component Access = No"
Last edit: 10 years 9 months ago by rich.
10 years 9 months ago - 10 years 9 months ago #173203 by colhiogroup
Thanks Rich. I enabled Direct Component Access and the 404 is now gone--I can access all categories and subcategories, but without the SEF URL. Disabling Direct Component Access causes the 404 to return for all categories.
How do I repair menu items? My main menu items are all working fine. I've tried disabling menu items one at a time, and even recreating them, with no luck. I also tried disabling a third party plugin and no change.
ETA: here are my enabled Kunena menu item configurations, could I have created a conflict?:
Main Menu:
Home menu title>>Recent Topics menu item type>>Newest Topics category id
Categories menu title>>Category List menu item type>>Top Level category id
Search menu title>>Search Topics menu item type
Hidden Menu:
Start New Topic menu title>>Create Topic menu item type>>All Categories category id
Last edit: 10 years 9 months ago by colhiogroup. Reason: listing active Kunena menu items
10 years 9 months ago #173204 by rich
154 No Replies kunenamenu view=topics&mode=noreplies forums/noreplies 155 My Topics kunenamenu view=topics&layout=user&mode=default forums/mylatest 157 Help kunenamenu view=misc forums/help
Only these 3 items in the Kunena menu are correctly. But I think it's better if you create all items new (Backend -> Kunena -> Tools -> Menu Manager -> Restore Kunena Menu).
10 years 9 months ago #173205 by colhiogroup
That worked! Thank you! Any idea what would cause my problem? SEF was working fine last time I tested the site (about a week or so ago)
10 years 9 months ago - 10 years 9 months ago #173206 by rich
Wrong menu items do not necessarily make mistakes, but the probability is present. Maybe it was the change from htaccess.txt to .htaccess. But if you want SEO with Apache Web Server then you need the .htaccess
www.kunena.org/docs/en/faq/seo
The following user(s) said Thank You: colhiogroup
Time to create page: 0.163 seconds
