Kunena 7.0.8 Released
Solved how to disable auto subscribe?
10 years 7 months ago #171852
by felixgr
how to disable auto subscribe? was created by felixgr
I have upgrade my Kunena to latest version 4.0.7 and now when a user reply a topic, it gets automatic subscription to that topic. It's absolutely crazy in large forums like mine, where a topic could have 20 or 30 replies in one day and a user could reply 10 to 20 topics. So, in one day he could receive hundreds of notification emails.
Please, help me in how to disable this!?
10 years 7 months ago #171854
by felixgr
Replied by felixgr on topic how to disable auto subscribe?
I have 72000 registered users, so, tell the users how to disable it manually in his profiles is not a "profesional" option. I need the SQL sentence and instructions on where to disable it for new users.
10 years 7 months ago #171855
by 810
Replied by 810 on topic how to disable auto subscribe?
The following user(s) said Thank You: felixgr
10 years 7 months ago - 10 years 7 months ago #171857
by felixgr
Thanks, then solution is
Change #_ with your prefix.
What about new users? will them have it set to Yes or No? i'm using jomsocial, so register process is a different.
Related to this. How can i edit the text for the "new reply" notification email?
UPDATE `#__kunena_users` SET `canSubscribe` = '-1'
Last edit: 10 years 7 months ago by felixgr.
10 years 7 months ago #171858
by 810
new users get the default setting (configuration option). As far i know jomsocial does not have kunena user settings on their edit profile. So they can't change it thereself.
Only using by the buttons on the forum, for example subscribe category/topic.
For editing text you can edit the strings on:
plugins\kunena\community\language\en-GB\en-GB.plg_kunena_community.sys.ini
but you need to create a language override, else the strings are gone on a update.
10 years 7 months ago #171859
by felixgr
Yes, my users can disable it thereself because i have created a new option in the Kunena Menu to have direct acces to edit kunena user settings
The language string file that you pointed is the en-gb version, but i receive the emails in spanish language. In plugins\kunena\community\language there isn't es-ES folder or version of the file... so... where it could be?
Time to create page: 0.262 seconds
