Solved Text Not Wrapping
10 years 10 months ago #171428 by GT3
Text Not Wrapping was created by GT3
If i view my forum on a tablet such as a Nexus 7 or I reduce the size of the browser, everything responds as it should do, except for the post text. The text doesn't wrap, and goes off the page.
I've tried using the default Kunena template (Blue Eagle) and the same thing happens.
Any help would be very much appreciated.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : jsn_dona_pro | author: JoomlaShine.com | version: 1.0.4 | creationdate: 10/30/2015
Kunena default template details : JSN Dona | author: Joomlashine Team | version: 1.0.4 | creationdate: 10/30/2015
Kunena version detailed: Kunena 4.0.7 | 2015-11-16 [ Albareto ]
Third-party components: UddeIM 3.7
Plugins: None
Modules: Kunena Login 3.1.1 | Kunena Search 3.1.1
10 years 10 months ago #171430 by 810
Replied by 810 on topic Text Not Wrapping
website is down
10 years 10 months ago #171431 by 810
ok working now.
This is because that template isn't fully responsive.
you can apply this for the text:
#Kunena div.kmsgbody div.kmsgtext { word-wrap: break-word; overflow: hidden; margin-right: 60px; }
But still you don't see all the buttons correct.
Then you need to use a different kunena template.
10 years 10 months ago #171515 by GT3
Replied by GT3 on topic Text Not Wrapping
That's fixed the problem. Thank you for all your help, and I will inform the template producers of the issue as well.
Thanks again, and Happy Holidays! :)
Time to create page: 0.188 seconds
