Solved missing default blue eagle template
10 years 11 months ago #170766 by butchjax
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 2M
Joomla default template details : uneedo | author: arrowthemes | version: 1.0.4 | creationdate: August 2012
Kunena default template details : Uneedo | author: arrowthemes | version: 3.0.8 | creationdate: 2014-02-14
Kunena version detailed: Kunena 4.0.7 | 2015-11-16 [ Albareto ]
Third-party components: UddeIM 3.4
Plugins: Search - Kunena Search 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
10 years 11 months ago #170923 by butchjax
No updates? This is still a problem, though since this I updated the modules to 3.1.1 and that crashed my site. So now things are even worse...
10 years 11 months ago - 10 years 11 months ago #170925 by 810
i think your file permissions are wrong on some dirs, try with akeeba tools to fix the file permissions, and try to update.
Else enable the kunena debug, and tell us what the error message is.
Last edit: 10 years 11 months ago by 810.
10 years 11 months ago #170927 by butchjax
What permissions need to be on the template folder?
10 years 11 months ago #170930 by 810
10 years 11 months ago #170933 by butchjax
thanks, will check
Time to create page: 0.147 seconds
