Solved Kunena to import on a clean install
Problem with the backup I imported backup tables but gives me this error means what? here is the screenschot
Query SQL: Documentazione
-- Database: `Sql666197_1`
DELIMITER $$--
-- Procedure
CREATE DEFINER = `Sql666197`@`%` PROCEDURE `n73x8_TeraWurfl_FallBackDevices` ( current_fall_back VARCHAR( 64 ) ) BEGIN find_fallback : WHILE current_fall_back != 'root' DO SELECT capabilities
FROM n73x8_TeraWurflMerge
WHERE deviceID = current_fall_back;
IF FOUND_ROWS( ) =0 THEN LEAVE find_fallback;
END IF ;
SELECT fall_back
INTO current_fall_back;
END WHILE;
END$$
Messaggio di MySQL: Documentazione
#1304 - PROCEDURE n73x8_TeraWurfl_FallBackDevices already exists
- Thank you received: 2545
You should import only all kunena tables and the Joomla user tables. Not he complete backup.
I installed Joomla 3, without kunema tables, user tables were empty, the area code and the same, the amount by the panel file msql finishes loading and you see me error
1. Go in your database and delete all Kunena tables and the Jomla user tables.
2. Import your backup tables again (all Kunena tables and the Joomla user tables)
3. Go in "Backend -> Extensions -> Manage -> (tab) Database" and click on Fix button.
4. Install Kunena
allego file.sql
