Kunena 7.0.8 Released
Solved No upload avatar tab - Gravatar plugin not enabled
10 years 11 months ago #169167 by katenz
I've just migrated my forum from vbulletin to kunena but can't find a way to allow users to upload avatars. There is no tab in the profile although I think the configuration is all right. Can anyone help please?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 256M
Joomla default template details : LSB Default | author: Hannah Smith | version: 1.0.4 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.8 | creationdate: 2015-04-05
Kunena version detailed: Kunena 3.0.8 | 2015-04-05 [ Imperium ]
Third-party components: UddeIM 3.7
Plugins: None
10 years 11 months ago #169169 by 810
settings are ok.
You can't see the tab:
frontend - kunena - profile - edit - edit avatar
The following user(s) said Thank You: katenz
10 years 11 months ago #169173 by katenz
Thank you....the edit link was not showing due to CSS settings
Time to create page: 0.275 seconds
