Kunena 7.0.8 Released
Solved Annoying issue with system messages
11 years 21 hours ago - 11 years 21 hours ago #168408 by Nova
Hi
I've installed Kunena , configured etc, but unfortunatelly I noticed that after sending EVERY post on my new forum on the top of kunena appear "system message" info (on joomla green background). Something like this (I will try to translate it from my native language)
"MESSAGE
Your message/post has been sucessfully sent"
This happen every time after sending single post. Its very frustrating.
I have latest Kunena 4.0.5, latest joomla 3.4.3. In Kunena configuration there is disabled subscription, also disabled debugging mode.
My question is HOW TO DISABLE these ugly notifications in kunena?
Last edit: 11 years 21 hours ago by Nova.
11 years 21 hours ago #168409 by 810
add this on your joomla template css:
#system-message-container {display: none;}
11 years 20 hours ago - 11 years 20 hours ago #168410 by Nova
Thx for your reply 810 , but believe me... disabling system messages completely in joomla is not good idea. Many other plugins or components sometimes use it to inform user what is going on.
So this is definitely bad idea.
I think it should be correctly programmed inside of kunena. I still dont believe that there is no option to change that. Otherwise i will be forced to install phpbb3 - but i dont like this stuff.
Any other ideas? workarounds?
Last edit: 11 years 20 hours ago by Nova.
11 years 20 hours ago #168412 by rich
You can easily disable it. Go in backend to "Extensions > Language(s) > Overrides > (Filter)-Site > New". Enter in the field Language Constant this code:
COM_KUNENA_POST_SUCCESS_POSTED
Let empty the text field and save it. That's all.
11 years 18 hours ago #168414 by Nova
Hmmm. thats very interesting method..it even works!
I understand that i could delete also other infos in the same way..hmm..
Could you tell me what exactly file i'm editing ? (i prefer do that directly in notepad)
I cant find it in ...\administrator\components\com_kunena\language\my_language\file
There is no such entry like COM_KUNENA_POST_SUCCESS_POSTED
11 years 18 hours ago #168415 by rich
You find it in "root/language/your language/xx-XX.com_kunena.controllers.ini"
Fronten languages are in "root/language"
Backend languages are in "root/administrator/language"
The following user(s) said Thank You: Nova
Time to create page: 0.235 seconds
