Solved I can't display general statistics
11 years 3 months ago #167931 by kemadiyo
Hi, I updated my Kunena forum yesterday, from 3.0.7 to 4.0.5 and everything look is working well but I have a problem with the general statistics, it dissapeared! I tried to go to the Configuration---Extra---Stats Plugin Settings but the option is enable, so I'm lost. I'm working in local using xampp, I'm not in a hurry but I would like to update it. Thank you very much!!!
11 years 3 months ago #167938 by 810
could you add the kunena report.
11 years 3 months ago #167940 by kemadiyo
This is my kunena report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : rt_oculus | author: RocketTheme, LLC | version: 1.0 | creationdate: Unknown
Kunena default template details : Minerim | author: Alberto | version: 3.0.6 | creationdate: 2014-07-28
Kunena version detailed: Kunena 4.0.5 | 2015-08-17 [ Turnau ]
Third-party components: AlphaUserPoints 1.9.13 | UddeIM 3.4
Plugins: Search - Kunena Search 3.1.0 | Content - Kunena Discuss 3.1.0
Modules: Kunena Latest 3.1.1 | Kunena Stats 3.1.0 | Kunena Login 3.1.0 | Kunena Search 3.1.0
Thanks!!!
11 years 3 months ago #167942 by 810
could you check it with the default kunena template. Maybe your kunena template has a bug.
11 years 3 months ago #167943 by kemadiyo
I tried with Blue Eagle 4.0.5 and Crypsis 4.0.5 and problem persists...
11 years 3 months ago #167944 by 810
try to enable kunena debug.
Then reload page and login as admin, do you get any error
Time to create page: 0.146 seconds
