Solved SyntaxError: unreachable code after return statement
11 years 3 months ago #167910 by nickstarbright
Hi, I've upgraded Kunena from v3.0.1 to v4.
My configuration is Joomla 3.4.3,
PHP Version/5.5.12
Apache/2.4.9
When I turn on Inspect Element and click on debug I get an warning. The error is coming from the media/kunena/js/default.js file in kunena on line 332, here is the code:
fetchCached: function() { return false; if (!this.options.cache || !this.cached || !this.cached.length || this.cached.length >= this.options.maxChoices || this.queryValue) return false; this.update(this.filter(this.cached)); return true; },
SyntaxError: unreachable code after return statement. How do I fix this?
Thanks in Advance!
11 years 3 months ago #167915 by 810
mhh didn't see this issue before,
try to clean cache.
Please add kunena report
11 years 3 months ago #167929 by nickstarbright
Okay, here's what I've done. I've cleared the browser cache, then I purged joomla's cache.
Reloaded the page fired up Inspect Element again and the error is still present. Also it shows that it repeats twice. :huh:
11 years 3 months ago #168014 by xillibit
Can-you put here please your Kunena report configuration settings ?
Which with browser do-you encounter this issue ?
11 years 3 months ago #168031 by nickstarbright
I'm using firefox. I'll check chrome as well.
Here is my Kunena Report
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : protostar-backup | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.5 | creationdate: 2015-08-17
Kunena version detailed: Kunena 4.0.5 | 2015-08-17 [ Turnau ]
Third-party components: AlphaUserPoints 2.0.2 | CommunityBuilder 2.0.10
Plugins: None
Modules: Kunena Latest 3.1.1
11 years 3 months ago #168036 by xillibit
That's weird nobody has noticied this issue before
Which exact version of firefox are-you using ?
Time to create page: 0.146 seconds
