Solved Use English On Missing Strings not working as expected
11 years 4 months ago #166655 by Gianmarco Odorizzi
I am using K 4.0.3 with Crypsis template on an Italian website, but I get missing strings like: "(COM_KUNENA_X_TOPICS)" and "COM_KUNENA_BY_X " Is there a way to fix this?
See flavioodorizzi .com for reference,
Thank you
11 years 4 months ago #166656 by rich
It seems this function does not work. I've reported it.
Open the folder "language > it-IT" and open the it-IT.kunena_tmpl_crypsis.ini. Line 15-18 should be
COM_KUNENA_X_TOPICS_0 = "Nessuna discussione"
COM_KUNENA_X_TOPICS_1 = "%s discussione"
COM_KUNENA_X_TOPICS_MORE = "%s discussioni"
COM_KUNENA_BY_X = "da %s"
But it will not completely solve your problem. Italian language is not 100% translated.
11 years 4 months ago - 11 years 4 months ago #166658 by Gianmarco Odorizzi
thanks for the answer, I know, I am translating part of it so that at least every site string is translated.
Where are the language files?
If the location is /components/com_kunena/language, for some reason the it-IT folder is missing.
EDIT: just found it, they are in [root]/language. Thanks
Last edit: 11 years 4 months ago by Gianmarco Odorizzi.
