Solved Cannot edit a post more than once
11 years 4 months ago - 11 years 4 months ago #166283 by larleuch
As an administrator, if I want to edit a message in frontend, it works fine at first time.
If I want edit the same message one more time, the submit button doesn't work.
Is this a bug? or a configuration option ?
thanx for your help :)
Ben
Here is my report configuration :
Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 256M | Max file upload: 5M
Joomla default template details : yoo_nano2 | author: YOOtheme | version: 1.0.0 | creationdate: Unknown
Kunena version detailed: Kunena 4.0.1 | 2015-06-10 [ Alto ]
Third-party components: CommunityBuilder 1.9.1
Plugins: Content - Kunena Discuss 1.7.2
Last edit: 11 years 4 months ago by larleuch.
11 years 4 months ago #166284 by 810
you use a old version template:
Blue Eagle (default) | author: Kunena Team | version: 1.7.2
should be 4.0
11 years 4 months ago #166312 by larleuch
it works perfectly
Ben
