Solved Problem Kunena 3 Joomla 3.2 ">" signs
12 years 7 months ago #154785 by Ickoski1
Hello i have problem with kunena on joomla 3.2
Lets have a look:
[img
[img
I have this: ">" signs everywhere.
Anyone knows why?? Can help??
12 years 7 months ago #154787 by cotswoldphoto
It is because those elements are list items, and in a css file later than the Kunena ones your template has set that symbol has the default bullet point. I have found it easier in the Kunena admin area, Templates, Blue Eagle Template the last but one setting I set to Yes (Blend with Joomla Template), and then do my own thing inside my template css. But YMMV
There is always tomorrow. If there isn't, why worry? The world must be about to end!
12 years 7 months ago #154790 by Ickoski1
And somebody else mayby have solution for this problem.
I searched and did not find in template.css why this sign schows up.
12 years 7 months ago #154791 by 9themestore
Hi Ickoski1,
Please post your site url here if you site has been lived. That is fastest way to solve this problem.
Regards
12 years 7 months ago - 12 years 7 months ago #154792 by Ickoski1
Sory, this is the site: www.pomorskiprzewodnikwedkarski.pl/forum/
Direck link to forum, everywhere you can see this > sign...
Last edit: 12 years 7 months ago by Ickoski1.
12 years 7 months ago #154795 by 9themestore
Open the template.css file in the current Joomla! template and add below CSS rules to the bottom of file.
body #Kunena ul li:before, body #Kunena ul li:after { display: none; }
After save reload your site to view changed.
Hope this helps
The following user(s) said Thank You: Ickoski1
