Solved Kunena Button Problem (Go, Jump to)
12 years 9 months ago #153178 by sixtyfive
Hello Kunena Community,
i have a small Button problem on my Kunena Forum. Can't find the CSS file or property which i should change to fix it.
1. Problem on Index page. The Button is not shown on the right side as it should be and it's "touching" the selector.
2. Button is also on wrong place and under the selector.
I would be very happy about any help how to fix this. Thanks :)
12 years 9 months ago - 12 years 9 months ago #153179 by sozzled
G'day, sixtyfive, and welcome to our forum.
We might be able to help you with your problem if you watch the video vimeo.com/69818669
Last edit: 12 years 9 months ago by sozzled.
12 years 9 months ago #153180 by sixtyfive
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : gk_gamenews | author: GavickPro | version: 3.10.1 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Plugins: None
12 years 9 months ago #153181 by sozzled
Please upgrade to K 3.0.4 - there are some changes between the Blue Eagle template in K 3.0.3 and I don't want to confuse things by giving you misinformation.
12 years 9 months ago #153182 by sozzled
Add the following lines to the end of your Joomla site template CSS file:
#Kunena form#jumpto input.kbutton { float: right; }
Even though, using FireFox 26.0, I do not see the GO button underneath the select box at the bottom of the page, I think the CSS change that I indicated above will cure your problem. The issue arises because of what is defined in your Joomla site template. Upgrading to K 3.0.4 is something you should do in any event. ;)
I hope that helps.
12 years 9 months ago #153183 by sixtyfive
Hello Sir. I have sucessfully updated to the 3.0.4 version.
Time to create page: 0.151 seconds
