Bug Help upgrading 3rd-party K 2.0 template to make it compatible with K 3.0.4
12 years 9 months ago #152219 by plezi69
Hello everyone. I am trying to upgrade my current template to work with joomla 3.x and the latest kunena. So far, everything is going except for this line of codes <?php foreach ($tabmodules as $tabmodule) : ?>
<?php if (JDocumentHTML::countModules ( 'kunena_tab_'.$tabmodule )) : ?>
<a id="tktab-<?php echo $tabmodule; ?>" href="#" rel="tk-tab-<?php echo $tabmodule; ?>"><span class="tk-fronttab-<?php echo $tabmodule; ?>">. that is showing this error "Strict Standards: Non-static method JDocumentHTML::countModules() should not be called statically, assuming $this from incompatible context. Any ideas on how to fix this issue?
Thanks in advance for your help
12 years 9 months ago - 12 years 9 months ago #152220 by sozzled
G'day, plezi69, and welcome to Kunena.
You posted your question in the K 3.0 Blue Eagle Templates category which is for asking questions about the Kunena Blue Eagle template.
Please note the information posted at the top of this page:
This category is for discussing issues with the K 3.0 Blue Eagle template.
Are you trying to upgrade an old Kunena Blue Eagle template? It may help if you watched the video so that we know more about your situation.
Last edit: 12 years 9 months ago by sozzled.
12 years 9 months ago - 12 years 9 months ago #152221 by plezi69
Hi and thank you for the prompt response. I am actually trying to upgrade a customize template. I did not notice this rule for this section of the forum so I apology.
Here's the configuration report.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : jsn_air_pro | author: JoomlaShine.com | version: 2.0.1 | creationdate: Unknown
Kunena default template details : Bloggy - Kunena 2.x | author: www.TemplateKunena.com | version: 1.0.6 | creationdate: 15.12.2012
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Third-party components: Jomsocial 2.8.4
Plugins: None
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
Last edit: 12 years 9 months ago by plezi69.
12 years 9 months ago #152222 by 9themestore
Hi plezi69,
You are using a commercial template. I think you should contact with the template club, they will support you upgrade it.
12 years 9 months ago - 12 years 9 months ago #152226 by sozzled
Yes, this is not a template designed, developed or maintained by the Kunena team.
This topic was posted in the wrong category.
*** Topic moved ***
Please contact the author of the template you are using to find out if there is a version compatible with K 3.0.4 or, alternatively, use the K 3.0.4 Blue Eagle template.
The following user(s) said Thank You: plezi69
12 years 9 months ago #152260 by plezi69
Thank you guys. Unfortunately the developer is not responsive. A lot of its customers are having the same issues for a template that they have purchased and the developer disappear. Thanks anyway :(
