Solved Problem position kunena_profilebox
12 years 10 months ago - 12 years 10 months ago #151491 by Peppe-73
Hello, I wanted to customize the position kunena_profilebox, but I tried several times also different templates but can not see anything, how do I fix
thanks
link my forum www.mypcdoktor.it/forum.html
Last edit: 12 years 10 months ago by Peppe-73.
12 years 10 months ago #151492 by 9themestore
Hi Peppe-73,
How did you customize the kunena profilebox position? If you want to custom style for it, you can add the CSS style to the template.css file of your Joomla! template.
Regards,
12 years 10 months ago #151655 by Peppe-73
Hello, I am not very practical CSS code, if you please tell me what I have to add the command string for the location abbilitare kunena_profilebox
I do not know if I was clear, but I abbilitare position "kunena_profilebox" I tried creating a new module and type the location of kunena_profilebox but does not work
  • rich
  • rich's Avatar
  • Away
  • Kunena Moderator
  • Kunena Moderator
  • I like sunshine and flowers
12 years 10 months ago #151657 by rich
abbilitare = Italian word for activate?
If you create a module on this position, it will be shown automatically. if you use Joomla 3+, you must press "Enter" before you the position kunena_profilebox save. Otherwise it will not be saved.
Please also check the option "Menu Assignment" whether the module is displayed.
12 years 9 months ago - 12 years 9 months ago #152141 by Peppe-73
rich wrote: abbilitare = Italian word for activate?
Hi, sorry for the late reply, but I did not understand what you mean use Joomla 2.5.xe the position as mentioned above and screenschot and correct
Last edit: 12 years 9 months ago by Peppe-73.
  • rich
  • rich's Avatar
  • Away
  • Kunena Moderator
  • Kunena Moderator
12 years 9 months ago #152142 by rich
You have inserted the position "kunema_profilebox". Correct is kunena_profilebox
Time to create page: 0.296 seconds
