Solved Section headers invisible font
13 years 4 weeks ago #149791 by Shimei
I changed the category title color, and one category seemingly is invisible. I can't find, nor do I know how to change this to the font color of the other category titles. I want it to be #ff9c2e but instead it's the same color as the category background color.
Screen shot shows where the invisible category title is, and here's my forum: www.religiousverse.com/forum.html
And my config, just in case:
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 128M | Max file upload: 24M
Joomla default template details : rt_cerulean | author: RocketTheme, LLC | version: 1.2 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: Jomsocial 3.0.4
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 3.0.1 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Login 3.0.1
13 years 4 weeks ago #149792 by 9themestore
Hi Shimei,
Please copy and paste the bellow CSS code section to the joomla template style file.
body #Kunena .kheader h2 a:link { color: #fff !important; /* Change with your color code */ } body #Kunena .kheader h2 a:hover, body #Kunena .kheader h2 a:focus, body #Kunena .kheader h2 a:active { color: #fff !important; /* Change with your color code */ }
I used the Firebug add-on check it and it worked fine.
Regards,
The following user(s) said Thank You: Shimei
13 years 4 weeks ago #149793 by Shimei
Thank you very much 9themestore!
13 years 4 weeks ago - 13 years 4 weeks ago #149802 by sozzled
I think the reason that one (?) section had missing text (as shown in the picture in msg #1) is unrelated to font-color.
When I went to the site, all sections were like this; not just the one you mentioned in msg #1 of this topic. In your case, the section font requires a special font-family. My browser had wait while the font was retrieved from your site and, when this happens, any text using this font family is invisible. I realised, after a while, that when I refreshed the page all the text became visible.
It's not just a CSS style issue; it's also an issue caused by using an "unusual" font.
Last edit: 13 years 4 weeks ago by sozzled.
Time to create page: 0.152 seconds
