Solved installation issue with Joomla 3.3.6
11 years 4 months ago - 11 years 4 months ago #161572 by Enfield
I was repeatedly unsucessful to instal current version in Joomla 3.3.0. I also tried to upgrade Joomla to 3.3.6, but it failed again. I am sending log file, it is in Czech language, but I think for you is important error message. Thank you for any advice! :whistle:
I also noticed that content of my webiste www.enfieldmoto.cz disappeared and there is displayed following message:
Last edit: 11 years 4 months ago by Enfield.
11 years 4 months ago #161573 by 810
clear cache on the joomla backend, and try again.
If not working, then uninstall kunena and install kunena again.
11 years 4 months ago - 11 years 4 months ago #161574 by Enfield
I cleaned cache, but it did not help. How can I uninstall Kunena? I do not see it in Module manager. Should I make it in Extension manager or FTP? If yes, what all should be deleted?
Thank you very much!
11 years 4 months ago #161575 by 810
go to extentions manager - manage - serach for kunena - select all - click on uninstall
11 years 4 months ago #161576 by Enfield
Thank you very much, it helped :) Now it works :) I have a one more question. What is the correct way for language pack installation ? I am sorry, but I did not found it in documentation.
Thanks!
11 years 4 months ago #161580 by sozzled
Enfield wrote: What is the correct way for language pack installation ? I am sorry, but I did not found it in documentation.
See K 2.0 Language Installation Guide .
The following user(s) said Thank You: Enfield
