Question Totally Upgrading But Need Advice
12 years 3 months ago #158702 by jaxtertee
Hi all
I have Joomla 1.5.26 and Kunena 2.0.4 - I want to update it to the new version so can someone tell me in laymans terms what I need to do.
Do I have to upgrade Joomla first, then upgrade Kunena or what?
Cheers
Jay
12 years 3 months ago - 12 years 3 months ago #158703 by Shimei
You'll actually need to migrate Joomla. To make life easier you may want to consider migration tools that are available in the JED: extensions.joomla.org/extensions/migrati...omla-migration/15609
As far as I am aware you won't be able to upgrade to newest Kunena without first migrating/upgrading Joomla because of Kunena's minimum requirements. Check here to be sure: www.kunena.org/docs/K_3.0_Technical_Requirements
Last edit: 12 years 3 months ago by Shimei.
