Question Problems Kunena 2.0.4 to Kunena 3.0.1 - minimum system requirements not met
12 years 10 months ago #146876 by applehc
I'm trying update Kunena 2.0.4 to Kunena 3.0.1 and says the next error:
Thanks for the help.
The topic has been locked.
12 years 10 months ago #146881 by rich
Your system requirements are not sufficient. In this case, the installation will be aborted.
Minimum system requirements
12 years 8 months ago #148933 by Joeriv
I have THE samen problem what can i do About iT
12 years 8 months ago #148999 by Joeriv
Yes but i sprak dutch but i do not really now what it 's all
12 years 8 months ago - 12 years 8 months ago #149000 by sozzled
It means that if your site does not meet the minimum technical requirements and you cannot install K 3.0 on your website. What you probably need to do is to find a webhosting provider who can advise you if they meet the minimum technical requirements to allow you to install Kunena.
Last edit: 12 years 8 months ago by sozzled.
Time to create page: 0.464 seconds
