Kunena 7.0.8 Released
Solved K 1.7.2 on J! 1.5 to K 3.0.4 on J! 3.2
12 years 6 months ago - 12 years 6 months ago #153733 by jdill
I'm trying to upgrade kunena 1.7.2 to 3.0.4 (from an 1.5.26 joomla to 3.2)
When i make the install i see this :
Préparation de l'installation ... OK
Installation du plugin Kunena - Alphauserpoints ... OK
Installation du plugin Kunena - Community ... OK
Installation du plugin Kunena - Comprofiler ... OK
Installation du plugin Kunena - Gravatar ... OK
Installation du plugin Kunena - Uddeim ... OK
Installation du plugin Kunena - Kunena ... OK
Installation du plugin Kunena - Joomla ... OK
Créer kunena_aliases ... OK
Créer kunena_configuration ... OK
Créer kunena_keywords ... OK
Créer kunena_keywords_map ... OK
Créer kunena_topics ... OK
Créer kunena_user_categories ... OK
Créer kunena_user_read ... OK
Créer kunena_user_topics ... OK
Création d'alias de catégorie ... OK
Options de configuration de migration du schéma K2.0.0 ... OK
Conversion des messages lus vers le shéma de K2.0.0 ... OK
Base de donnée mise à jour vers la version 3.0.4 ... OK
But after, nothing ... i let my computer turn on all the night (8hours) and the installation stay stucked by this Sql request :
UPDATE gvrsi_kunena_topics AS tt INNER JOIN ( SELECT m.thread, m.hold, COUNT( DISTINCT m.id ) AS posts, COUNT( a.id ) AS attachments, MIN( m.time ) AS mintime, MAX( m.time ) AS maxtime FROM gvrsi_kunena_messages AS m LEFT JOIN gvrsi_kunena_attachments AS a ON m.id = a.mesid WHERE m.moved =0 GROUP BY m.thread, m.hold ) AS c ON tt.id = c.thread INNER JOIN gvrsi_kunena_messages AS mmin ON c.thread = mmin.thread AND mmin.hold = tt.hold AND mmin.time = c.mintime INNER JOIN gvrsi_kunena_messages AS mmax ON c.thread = mmax.thread AND mmax.hold = tt.hold AND mmax.time = c.maxtime INNER JOIN gvrsi_kunena_messages_text AS tmin ON tmin.mesid = mmin.id INNER JOIN gvrsi_kunena_messages_text AS tmax ON tmax.mesid = mmax.id SET tt.posts = c.posts, tt.attachments = c.attachments, tt.first_post_id = mmin.id, tt.first_post_time = mmin.time, tt.first_post_userid = mmin.userid, tt.first_post_message = tmin.message, tt.first_post_guest_name = mmin.name, tt.last_post_id = mmax.id, tt.last_post_time = mmax.time, tt.last_post_userid = mmax.userid, tt.last_post_message = tmax.message, tt.last_post_guest_name = mmax.name WHERE moved_id =0 AND ( tt.id BETWEEN 1 AND 5056 )
Someone can help me ? At least a tutorial on how to make it step by step directly with Sql ?
I'm working with Mamp (local), Php 5.3.14, libmysql 5.5.25
I edit my php.ini and set up all the size et time limit, etc ... , so that's not the problem.
In the table from kunena 1.7.2, there are around 40K messages.
i'm a french speaker, so sorry for my error :)
Thank you :)
Last edit: 12 years 6 months ago by jdill.
12 years 6 months ago #153745 by sozzled
12 years 6 months ago #153748 by jdill
I uploaded a version online, but i have problem with grant (lock table) (1044 error). As i don't have access to this i have to wait until tomorrow to fix that.
I try again on local, i have now an error 500 ... I'll try online tomorrow , but i don't think that'll work.
I also look for the sql request to do all by myself, i see the sql file into kunena pkg > install> sql , with migrate and upload directory but i don't know how to proceed and i find nothing with google.
12 years 6 months ago #153764 by jdill
So,
i just try with an online version, and i have the exact same situation.
The provider is Ovh (with their offer Vps)
12 years 6 months ago #153778 by sozzled
How did you migrate from J! 1.5.26 to J! 3.2.2?
12 years 6 months ago #153784 by jdill
with redMigrator
but it's ok, i found a way !
I install kunena 2 on my Joomla 1.5, i copy the kunena table on my new installation (and i change the prefix)
Then, i launch the installation of kunena 3 on my joomla 3.2
I just have to configure the categories permissions, but it's seems to be a well-know issue
Time to create page: 0.356 seconds
