Solved J! 3.0.2 is not supported
I've tried to find the latest versions of Kunena compatible with my version of joomla, but I don't know where I have to looking for. Anybody can help me?
It's higly recommended to upgrade to a more recent version
There is no version of Kunena that is compatible with J! 3.0.2.uribrugal wrote: Can I not find an older version of Kunena that is compatible with Joomla 3.0.2?
The question you need to answer is a simple one. Do you want to use Kunena, yes or no? If you want to use Kunena then must upgrade Joomla. If you do not want to use Kunena thank you for your question but we are sorry, we cannot help you.
I thougth it would be more complicated upgrade joomla
