Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Solved K 1.7 shows as "protected extension" after upgrade to K 3.0.4
12 years 2 months ago - 12 years 2 months ago #151876 by huuanito
After a successful upgrade to 3.04 from 1.7 I'm seeing lot's of errors in the forum like:
Notice: Undefined property via __get(): banned in /home/mysite/public_html/libraries/kunena/user/user.php on line 311 in /home/mysite/public_html/libraries/kunena/user/user.php on line 701
When I look in the extensions manager it still shows 1.7 for a couple of the entries:
Kunena Forum - English Administrator Language
Kunena Forum - English Site Language
and they both show as locked.
Maybe that has nothing to do with the errors.
Anyway I'm wondering if there is a way to update those two files and also to get rid of the errors.
Thanks.
Last edit: 12 years 2 months ago by huuanito. Reason: add solved
12 years 2 months ago #151888 by xillibit
Can-you put here your Kunena report configuration settings ?
12 years 2 months ago #151897 by huuanito
Sorry, should have done that first time around. Here you go:
Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : ja_graphite | author: JoomlArt.com | version: 1.0.5 | creationdate: Unknown
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Third-party components: CommunityBuilder 1.9.1 | UddeIM 3.2
Plugins: None
Modules: Kunena Latest 1.7.0
12 years 2 months ago #151900 by xillibit
huuanito wrote: When I look in the extensions manager it still shows 1.7 for a couple of the entries:
These two thing has nothing to do with errors
You can disable display of php errors messages in Joomla! configuration panel.
The following user(s) said Thank You: huuanito
12 years 2 months ago #151905 by huuanito
Thanks. As far as I know display of php errors is disabled in Joomla configuration panel: Debug Settings/Debug System = No
Debug Settings/Debug Language = No
OK I see it now. I was on my test site for testing the Kunena upgrade and php.ini had display_errors = On
Fixed. Merci Beaucoup.
12 years 2 months ago #151906 by xillibit
Can-you check in Kunena users manager if the users are banned or not ?
Sometime it happens when you migrate from pevious version by usign some backup tools
Time to create page: 0.281 seconds
