Kunena 6.4.13 Released
Solved Kunena 3.0 has not been installed, aborting!
12 years 11 months ago #148181 by LUH3417
I get the following error if I try to install Kunena pkg_kunena_languages_v3.0.2_2013-08-18.zip.
JLIB_INSTALLER_ABORT_PACKAGE_INSTALL_CUSTOM_INSTALL_FAILURE
The Technical Requirements are all cheked and ok:
Datenbankversion 5.1.70-0ubuntu0.10.04.1
Datenbankzeichensatz utf8_general_ci
PHP-Version 5.3.2-1ubuntu4.20
Webserver Apache
PHP-Interface für den Webserver apache2handler
Joomla!-Version Joomla! 2.5.14 Stable [ Ember ] 01-August-2013 14:00 GMT
Joomla!-Plattform-Version Joomla Platform 11.4.0 Stable [ Brian Kernighan ] 03-Jan-2012 00:00 GMT
Has anybody an idea what could be wrong?
P.S:
I did try to install an older Kunena Version but did not found any files on this site.
Thank you
12 years 11 months ago #148190 by xillibit
Because the language package has a weight of 2,9 Mb, you have maybe some limitations in your php.ini.
So, check in your php.ini to see if the value upload_max_filesize is more higher than 2 M.
12 years 11 months ago - 12 years 11 months ago #148350 by LUH3417
No, all params and requirements I have checked. upload_max_filesize is 128M.
I also did try to upload a tar.gz package instead the ZIP.
But now I got it I did try to install the language pack before the kunena itself.
The error was related to the language pack.
Lucas
Last edit: 12 years 11 months ago by LUH3417.
Time to create page: 0.226 seconds
