Solved Cannot Install K 3.0 - my site does does not meet technical requirements - MySQL 4.1
- dianaNashif
- Senior Member
My installation did not go well........I got these errors:
MySQL 5.0.96-community is not supported. Minimum required version is Mysql 5.1 but is is highly recommended to use mysql 5.5 or later.
JLIB_INSTALLER_ABORT_PACKAGE_INSTALL_CUSTOM_FAILURE
I talked to my hosting company and they said that is a big MsQL jump and that it might break all my other sites hosted on our dedicated server.
Just curious, why such a big change when other extensions are compatible with 4.1 and above?
Diana
Just ask them to migrate to mysql 5.1 in a first time, which extensions are compatibles with mysql 4.1 ?
Just look the Joomla! requirement : docs.joomla.org/Technical_requirements , Joomla 2.5 supports as minimum mysql 5.0.4 and Joomla! 3.0 mysql 5.1 like Kunena 3.0
- dianaNashif
- Senior Member
How long can I go with only upgrading to 5.1 before it becomes an issue? I really like to make sure our sites are running as smoothly and error free as possible.
Diana
The K 3.0 installation process checks for the minimum version requirement for MySQL - it needs to be MySQL 5.1.0 or higher (MySQL 5.5.0 or higher is recommended) an if this minimum requirement is not et then the installation procedure will end; in previous versions of Kunena , the installation processes may not, perhaps, have so rigorously checked the MySQL version minimum requirements. As far as K 3.0 is concerned, that's the "deal": the K 3.0 installation/upgrade procedure pre-check ensures that your site has MySQL 5.1.0 as a minimum; this information is stated quite clearly in the Kunena installation guides.
- dianaNashif
- Senior Member
I did go to the Wiki, but it is the same stuff so it is easy to overlook a small number change.
Nothing unfortunate, just asking a question and xillibit helped me greatly.
