Kunena 7.0.8 Released
Question XAMPP 1.8.1: Fatal errors during upgrade from K 2.0.4
13 years 3 months ago - 13 years 3 months ago #144660 by Wild Duck
Hi all
Before upgrade my production site, I always do a restore in my test local server to ensure that all will go ok.
I installed Xampp 1.8.1 and restored my backup succesfully. All went ok.
After that, I tried to upgrade Kunena (K 2.0.4) to K 3.0, but the process stopped with fatal error message:
After that every time I try to enter in kunena administration backend the installation process begins again with the same result. Of course, the forum went down whith maintenance message on screen.
What can be wrong?
Are there any known issue with Xampp installation?
The kunena configuration report before try to install:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 8M
Joomla default template details : acero_template | author: Angie Radtke | version: 2.5.0 | creationdate: 21 May 2010
Third-party components: UddeIM 2.6
Plugins: None
Thank you in advance.
Last edit: 13 years 3 months ago by Wild Duck.
The topic has been locked.
13 years 3 months ago #144670 by xillibit
I see no error message or fatal error on your sceenshot, what third party plugins do you have installed on your joomla onstallation ?
13 years 3 months ago #144674 by Mortti
xillibit wrote: Hello,
Top of that is in english:
COM_KUNENA_INSTALL_PLEASE_WAIT="Installing Kunena, please wait..."
COM_KUNENA_INSTALL_ERROR_FATAL="Sorry, installation failed on fatal error!"
I checked from github that es-ES.com_kunena.install.ini and en-GB.com_kunena.install.ini files... github.com/Kunena/Kunena-Forum/tree/deve...unena/admin/language
13 years 3 months ago - 13 years 3 months ago #144683 by Wild Duck
Hi Xillibit & Mortti. Thank you for your replies.
Yes, in my screenshot the text is:
and just at the begining the process stopped, and the message progress says:
"Sorry, installation failed on fatal error", but nothing more... no error explain...
If I click on "installation details" the message appears:
"Preparing installation" - Nothing more
No 3rd plugins installed. Only kunena, udde IM and template.
Can be a languaje packaje error?
13 years 3 months ago - 13 years 3 months ago #144718 by Mortti
Wild Duck wrote: Can be a languaje packaje error?
I think it's not. Check your Apache Error Log File what it's give when you try upgrade.
www.kunena.org/docs/HTTP_500_Internal_Server_Error
Last edit: 13 years 3 months ago by Mortti.
13 years 3 months ago #144754 by mibert
Hi there,
I am facing exactly same issue and the Error message during Kunena installation is saying the following:
Warning: Invalid argument supplied for foreach() in /homepages/administrator/components/com_kunena/install/schema.php on line 296
Fatal error: Class 'KunenaFactory' not found in /homepages/administrator/components/com_kunena/install/model.php on line 700
Does this say something to you, which helps finding a solution?
Best regards
Michael
Time to create page: 0.293 seconds
