Solved K 3.0.0: Danish time zone display problem solved
13 years 6 months ago #144185 by BlackChart
Just upgraded my site to Kunena 3, but timezone isn't displayed correct.
Time stamp for posts is like this (Yes yes it's in Danish): I dag CEST:26
Translated it's: Today CEST:26
Where do I change this?
It's a problem both inside forum and in Kunena Latest block on frontpage.
Config:
Database collation check: joom_kunena_pratings have wrong collation of type latin1_swedish_ci on field users_ip joom_kunena_pratings have wrong collation of type latin1_swedish_ci on field option
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : | author: | version: | creationdate:
Kunena default template details : SD-Aphotic 2.0 (Version II) | author: SnilloC Designs | version: 2.0 | creationdate: 2012-07-28
Third-party components: CommunityBuilder 1.9 | UddeIM 2.9
Plugins: None
Modules: Kunena Latest 3.0.0 | Kunena Stats 3.0.0 | Kunena Search 3.0.0
13 years 6 months ago #144186 by BlackChart
Solved :)
da-DK.com_kunena.libraries.ini
Line 122 should be as this:
COM_KUNENA_LIB_DATETIME_FMT="d M Y H:i"
Line 124 like this:
COM_KUNENA_LIB_DATE_FMT="d M Y"
Line 125 like this:
COM_KUNENA_LIB_TIME_FMT="H:i"
The following user(s) said Thank You: Yxos
13 years 5 months ago #145097 by Yxos
Thanks for sharing. I updated Transifex accordingly, so that the problem is solved with the next release of the language pack.
Until then I attach an updated Danish language pack for the benefit of all :)
It can be installed like all other extensions on top of the current version and will work instantly.
/Yxos, Kunena Translator, da-DK.
Overvej at abonnere på kategorien www.kunena.org/forum/48-Danish
13 years 4 months ago - 13 years 4 months ago #145974 by Yxos
Well, it WOULD have been fixed, if only they would have imported the latest Transifex changes before releasing a new language pack :blink:
Here's a revised Danish file, that fixes the issue for 3.0.1 - again.
P.S. I don't know why Kunena renames my file... Please rename the attached file after download to "com_kunena_da-DK_v3.0.1.zip"
Last edit: 13 years 4 months ago by sozzled. Reason: Changed subject
13 years 4 months ago - 13 years 4 months ago #145983 by rich
It is not necessary to rename the package. The installation also works without rename.
It's reported on git.
github.com/Kunena/Kunena-Forum/pull/1826
Last edit: 13 years 4 months ago by sozzled. Reason: Change subject
13 years 3 months ago - 13 years 3 months ago #147700 by Yxos
Here we go again. This time for 3.0.2.
At least the file-rename problem seems to have been fixed now :woohoo:
Last edit: 13 years 3 months ago by sozzled. Reason: Minor change to subject
