Please Read This First:
Do not use this category for:
Solved Section collapse/uncollapse issue
2 years 2 months ago #232061 by AlexRag
Anyone having issues getting the accordian effect to open up categories with the Aurelia template
The inspector point to this but when I click the -/+ button the topics appear momentarily then disappear again.
<button class="kbtn collapsed" type="button" aria-expanded="true" aria-controls="section9" data-bs-toggle="collapse" data-bs-target="#section9">
            <span class="cat-show"><i class="fa fa-plus"></i></span>
            <span class="cat-hide"><i class="fa fa-minus"></i></span>
          </button>
Kunena 6.34
Joomla 4.4.6
2 years 1 month ago #232064 by Pinkeltje
Unable to reproduce, nor on this forum nor on my own forum. But your css is strange. It should be like  this:
<h2 class="btn-toolbar float-end">                                              <button class="btn btn-outline-primary btn-sm" type="button" aria-expanded="true" aria-controls="section3" data-bs-toggle="collapse" data-bs-target="#section3"><i class="fas fa-compress" aria-hidden="true"></i></button>                     </h2>
Did you enable bootstrap? Could it be a conflict with your Joomla template?
2 years 1 month ago - 2 years 1 month ago #232072 by AlexRag
Thanks for the reply.
There does a appear to be a conflict with the popular YooTheme template.
I found a workaround for the default Aurelia Theme ( yootheme.com/support/question/159687 ) but have not had any luck with ones the two I bought at 9themes.
I've tried to reach out to them but have not had any response is several weeks.    The issue is actually appearing  on their own demo site too. ( 9themestore.com/index.php/kunena-templates/nts-ksumo ).
I also bought NTS KGrid but that one is even worse with YooTheme.  The whole layout is a train wreck.  But I tested this in a RocketTheme themed site and it looks okay.
Last edit: 2 years 1 month ago by AlexRag.
2 years 1 month ago #232075 by Pinkeltje
Try this in Yootheme custom code script
 UIkit.util.ready(function(){UIkit.util.removeClass(UIkit.util.$('#search-tm-3-modal'),'uk-modal-full')}) const tooltipTriggerList = document.querySelectorAll('[data-bs-toggle="tooltip"]')
2 years 1 month ago #232095 by AlexRag
Thanks.  It didn't work, but the developer at 9Themes came through and fixed the styling conflicts for both templates I purchased so my issue has been resolved!
