Please Read This First:
Do not use this category for:
Solved Subject fields-length is too short
3 years 3 months ago #228931 by lemur
Hello
This is a trifle, but unpleasant.
The field for the subject is very short by me, it is inconvenient when typing.
How to make this field longer (ideally, the entire width of the form).
Subject fields-length is too short.
Signature:
Many thanks to Rich and the other advisors.
3 years 3 months ago #228932 by Leen
I think you Purity ||| used ?
in Purity IV that problem is gone
With kind regards
Leen
The following user(s) said Thank You: lemur
3 years 3 months ago #228933 by lemur
Thank you.
You're right, I use Purity |||.
Does your answer mean that this problem cannot be solved within the Kunena?
(If it's easy for you, evaluate whether it's always possible to switch from Purity ||| on Purity |V)?
Best regards.
Signature:
3 years 3 months ago #228934 by Leen
what you can try is in
Edit file "‎/templates/purity_iii/css/custom.css" in template "purity_iii". to post the code
.form-control {
width: 500px !important;
With kind regards
Leen
3 years 3 months ago #228935 by lemur
It's cool!
Your hint works.
Thank you very much
Signature:
