Please Read This First:
Do not use this category for:
Question Template issues with modals in BBcode editor
4 years 7 months ago #222660 by loppan
Hi!
This issue has been discussed before, and I've tried all solutions posted so far, but none of them worked for me.
Problem is, when I'm in the BBCode editor, the buttons that open in a modal does not work. It just display a greyed out screen.
I would assume this is a CSS problem. I think the modal is there somewhere, just not in the right position :).
I've tried to adjust the z-index. I've tried to paste all CSS code I've found on this forum. Still no luck.
If I set the "Quick reply"-button to open in a modal, that modal works fine actually. Also with the CKeditor, modals work.
If I switch to protostar, all modals work.
My template is really nothing special, it's based off Boostrap 3.4.1 and very clean overall (It's the home 3 template from olympian themes. Quality stuff :))
I have tried to disable ALL my custom CSS, modal still don't work. I think the problem lies within a conflict with the bootstrap framework that's loaded even if I disable my own custom.css and template.css.
I just can't figure this one out. Please help :).
Here is an URL for testing (guest posting works so feel free ;))
www.crashdiet.org/forum/for-testing/5725-my-first-test-topic
Configuration report posted below.
Truly grateful for advice. Thank you!
Best wishes
Peter
htaccess: Exists | PHP environment: Max execution time: 200 seconds | Max execution memory: 256M | Max file upload: 30M
Joomla default template details : Horme_3_pro | author: Spyros Petrakis | version: 1.9.6 | creationdate: 13/11/2019
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.2.8 | creationdate: 2022-01-01
Kunena template params:
Kunena version detailed: Kunena 5.2.8 | 2022-01-01 [ Alcora ]
Third-party components: CommunityBuilder 2.6.4
Plugins: None
4 years 7 months ago - 4 years 7 months ago #222668 by Leen
Hi.
there is yourwebsite\templates\horme_3\css\ possibly a horme.bootstrap.min.css
there's a line at the bottom with ".hide{display:none !important}"
if you put it on ".hide{display:all !important}"
then  you get more.
it may not be a very nice solution but maybe you can get on with it then
I have sent my modified version as an attachment(zipped)
With kind regards
Leen
Last edit: 4 years 7 months ago by Leen.
The following user(s) said Thank You: loppan
4 years 7 months ago #222680 by loppan
Wow, Leen! Thank you very much for this. Now when I can see something, it's easier to move forward :D. Well, I guess the best solution for me would be to clone the crypsis template and modify the BBCode editor so that it opens modals in the same way as in the rest of kunena.
All feels doable now when I can actually see what's going on :D.
Thanks again, really appreciate this!
Best wishes
Peter
4 years 7 months ago #222683 by Leen
You're welcome and good luck finding a better solution.
If that works, please let us know here so that someone else can enjoy it too.
Have a nice day
Leen
With kind regards
Leen
Time to create page: 0.160 seconds
