Please Read This First:
Do not use this category for:
Solved Some large images in articles are deformed in Chrome and Edge
5 years 3 months ago #218272 by krapet
I have set size limit for uploaded images to 1280 x 1280.
In file kunena.css is height limit for images -> max-height: 800px.
When images are landscape then they are displayed correctly.
When images are portrait and are higher than 800px then its height is reduced to this limit but width is not recalculated.
This issue was observed in Chrome and Edge. Firefox display images correctly.
My solution is to add following code in CSS (kunena.css):
#kunena.layout div.kmsgbody div.kmsgtext img  { object-fit: scale-down; }
Kunena 5.2.5, BlueEagle 1.6.5
5 years 3 months ago #218286 by 9themestore
@krapet,
Can you post your website url to here? We will check and find the solution for this issue.
Regards,
5 years 3 months ago #218303 by krapet
kkplzen.eu/index.php/forum/5-kaktusy/434...ycium?start=30#73103
Now I have fixed CSS so images are displayed correctly.
To see deformation it is necessary to disable this fix. (Inspect element : Ctrl+Shift+I)
The following user(s) said Thank You: 9themestore
5 years 2 months ago - 5 years 2 months ago #218662 by PhilF51`
Aha!    Good work on a fix
Last edit: 5 years 2 months ago by PhilF51`.
