Please Read This First:
Do not use this category for:
Solved Editor layout issue after last upgrading
6 years 2 months ago #213777 by ita4012
Hi. I have an editor layout issue after last upgrading. You can see it in the picture in attachment, or at www.waterwind.it/new/en/forum-en.html .
Any solution available?
6 years 2 months ago #213779 by Leen
Hi
looks like normal just maybe clean your web browser cache CTRL + F5
With kind regards
Leen
6 years 2 months ago #213780 by ita4012
Leen wrote: Hi
It doesn't work. Hi still have the same problem.
It's strange that on my demo site, with the same settings, I don't see any problem.
6 years 2 months ago #213781 by ita4012
It's the same problem that I had some time ago, and that I reported in this thread: www.kunena.org/forum/k5-1-support/158666...-smartphone-any-more
6 years 2 months ago - 6 years 2 months ago #213782 by Leen
if your demo site working then compare
in the administrator section of your template
Templates: Edit (Shape5_vertex) the HTML folder
or there is a difference with your problem site.
and or compare the template settings in eg tab general or
there are sliders different and also check the javascript settings tab
ps
and clear the website cache
With kind regards
Leen
Last edit: 6 years 2 months ago by Leen.
The following user(s) said Thank You: ita4012
6 years 2 months ago #213783 by ita4012
Thank you very much for help, Leen. I will check asap.
Regards
