Please Read This First:
Do not use this category for:
Question Logged in module for registered users not displaying properly.
7 years 2 months ago - 7 years 2 months ago #211126 by kominid
EDIT:
fixfaqs.ddns.net/joomla3-3.4.1/ - forgot my URL
EDIT.
Hi, I have sorted all my current problems except for the 'logged in' section for registered users.
Could the developers have a look and let me know if this is an easy fix? The extent of my programming relies on 'inspect' from chrome and a file search utility that can search inside files! :P
I have attached my config report and also an image of the issue.
TIA,
DB
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: 4/30/2012
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.14 | creationdate: 2019-08-13
Kunena template params:
Kunena version detailed: Kunena 5.1.14 | 2019-08-13 [ Nix ]
Plugins: None
Modules: Kunena Login 5.1.1
Last edit: 7 years 2 months ago by kominid. Reason: Forgot URL
7 years 2 months ago #211128 by rich
Try this code in your custom.less :
.navbar .nav > li { overflow: inherit; } .navbar .nav>li:before { display: none; }
The following user(s) said Thank You: kominid
7 years 2 months ago #211133 by kominid
Hi Rich, Thanks so much for your reply. It did fix the issue, but afterwards I found that I had broken all my kunena links so I had to roll back a bit. I've tried the custom.less addition you mentioned with the current incarnation of the site and it doesn't work again :(
Could you have another look for me or maybe tell me how to troubleshoot myself?
I have attached my 'new' config report here.
TIA
DB
Plugins: None
7 years 2 months ago #211136 by rich
The code should not affect the links. You have assigned the Kunena menu to the module for the horizontal menu. Please undo this and test again.
7 years 2 months ago #211138 by kominid
Hi again, so the widget is working now. Thank you.
It wasn't the code that messed up the links it was me playing with the kunena menu.
I didn't realise I'd messed them up until afterwards.
7 years 2 months ago #211140 by kominid
Well I think all my bugs are solved. Thank you for being so clever!
I have one other issue but I don't want to flood the forum.
If you could let me know in a reply if I can post my last issue, that would be great.
If not I'll wait a while and then post.
Thanks again
DB
Time to create page: 0.205 seconds
