Please Read This First:
Do not use this category for:
Solved Error 500 on clicking "Preferences"
8 years 1 month ago #204488 by eunger
Hi there,
We are getting an http "500" error message when one clicks on the "preference" link from the vertical status bar of one user (see screen capture attached).
I first thought it could be linked to our theme but our designer says such a problem cannot be linked to css issues.
In fact, the "preference" link points to the www.mywebsite.com/index.php/fr/forum/pro...lastname?avatartab=1 URL.
The former yields a 500 error message regardless whether it is accessed via the Kunena's vertical status bar, or by being directly inserted in a browser's address bar.
Thus, it is the URL itself which has a problem.
Any thoughts on what could be at the root cause of this abnormal behavior?
Thanks in advance for your insights.
Cheers,
Eric
8 years 1 month ago #204503 by rich
Please enable the Kunena debug mode for more exact error message (Kunena configuration -> tab General) and create also a Configuration Report
8 years 1 month ago #204560 by eunger
Hello-
Thank you Rich for your answer.
I was eventually able to troubleshoot and solve the problem on my own.
For those encountering the same kind of problem, here are my findings. The problem was caused by a file part of my Kunena template (named "Joomspirit"), located here:
..\components\com_kunena\template\joomspirit\layouts\widget\login\logout\default.php
The snippet of code below is from this file. The part in red is what adds the erroneous link to profile configuration page which causes a 500 error. I didn't need this feature, so I simply commented out this entire excerpt. It now works like a charm.
<div id="settings">
<a href="<?php echo $this->profile_edit_url; ?>" class="btn btn-link">
<?php echo KunenaIcons::cog();?>
<?php echo JText::_('COM_KUNENA_LOGOUTMENU_LABEL_PREFERENCES'); ?>
</a>
</div>
Cheers,
Eric
