Please Read This First:
Do not use this category for:
Solved Editor images not visible after joomla update
8 years 9 months ago - 8 years 9 months ago #198077 by gridfree
Kunena 5.0.13 joomla 3.8.3
updated kunena and editor icon images are no longer visible.
Not Found
The requested URL /media/kunena/cache/crypsisb3/css/components/com_kunena/template/crypsisb3/assets/images/bold.png was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Developer shows:
Failed to load resource: the server responded with a status of 404 (Not Found)
GET www.omnipotence.ca/media/kunena/cache/cr...sets/images/bold.png 404 (Not Found)
htaccess: Exists | PHP environment: Max execution time: 90 seconds | Max execution memory: 300M | Max file upload: 300M
Joomla default template details : organic_food | author: DH sign | version: 2.0 | creationdate: Jan 2016
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.0.13 | creationdate: 2017-12-31
Kunena template params:
Kunena version detailed: Kunena 5.0.13 | 2017-12-31 [ Meerkat ]
Third-party components: CommunityBuilder 2.1.3 | UddeIM 3.8
Plugins: None
I am a newbie, any help would be greatly appreciated, thank you
Last edit: 8 years 9 months ago by gridfree.
8 years 9 months ago #198264 by gridfree
No one can help with this issue?
8 years 9 months ago #198265 by 810
1) Try clean cache: backend - cache - clean cache
2) Go to backend - kunena - plugins - rebuild
8 years 9 months ago #198266 by gridfree
did both, still same issue
8 years 9 months ago #198268 by 810
do you use any compress plugin? please disable the kunena part.
8 years 9 months ago #198272 by gridfree
No do not have any compress plugins,
disable kunena part?
Time to create page: 0.221 seconds
