Please Read This First:
Do not use this category for:
Question Sugesting fixes for crypsis. Where?
8 years 9 months ago - 8 years 9 months ago #197524 by TwizyForum
Playing with the template I found a few things that might be worth changing to fix some problems that maybe concern other users.
Where can I suggest those changes, so that I do not have to override and diff those CSS forever ;-)
In one case I noticed that with fluid option in the protostar template the profile side menu does act up.
In the first post, the "Autor" indicator slips to the right.
Putting the avatar picture in its own line item will fix this, and should not be a problem for anyone?
/layouts/user/profile/default.php
<?php if ($avatar) : ?> <li> <?php echo $user->getLink($avatar, null, ''); ?> </li> <li> <?php if (isset($this->topic_starter) && $this->topic_starter) : ?> <span class="hidden-phone topic-starter <?php if (KunenaFactory::getTemplate()->params->get('avatarType') == 'img-circle') {echo 'topic-starter-circle';};?>"><?php echo JText::_('COM_KUNENA_TOPIC_AUTHOR') ?></span> <?php endif;?> <?php /*if ($user->isModerator()) : */?><!-- <span class="<?php /*if (KunenaFactory::getTemplate()->params->get('avatarType') == 'img-circle') {echo 'topic-moderator-circle';};*/?> topic-moderator"><?php /*echo JText::_('COM_KUNENA_TEAM_MEMBER') */?></span> --><?php /*endif;*/?> </li> <?php endif; ?>
With this simple fix the page looks good , even in 1440px
Last edit: 8 years 9 months ago by TwizyForum.
