Please Read This First:
Do not use this category for:
Solved Kunena showing multiples
9 years 3 weeks ago #196548 by originalhandy
I have a forum located here www.claytonnewmexico.net/forums.html
When I upgraded from j3.2 to j3.5 (always current on Kunena) it shows two or three logins. It is the same when logged in. Any suggestions ?
In Kunena diagnostics everything passed.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : clayton | author: ComputerSolutions.US | version: 1.0 | creationdate: 2015-05-28
Kunena default template details : Crypsis | author: Kunena Team | version: 5.0.11 | creationdate: 2017-09-02
Kunena template params:
Kunena version detailed: Kunena 5.0.11 | 2017-09-02 [ Kinkajou ]
Plugins: None
9 years 3 weeks ago #196551 by rich
Replied by rich on topic Kunena showing multiples
Please try in backend "Kunena -> Templates -> Crypsis -> Basic Settings -> Load Bootstrap css = Yes". But I'm not sure if this solves all the problems.
9 years 3 weeks ago #196563 by originalhandy
Appreciate the answer, that worked with regards the doubling up of things but hte login box is hidden and cant login with it.
9 years 3 weeks ago #196620 by rich
Add this codes in your custom.less . The first code is for login, and the second code removes the hooks in the profile box left of the messages.
.layout#kunena .dropdown { overflow-y: visible; } .layout#kunena ul>li:before { display: none; }
The following user(s) said Thank You: originalhandy
9 years 2 weeks ago #196652 by originalhandy
Thank you sir, that worked a treat!
Time to create page: 0.158 seconds
