Please Read This First:
Do not use this category for:
Solved How to hide bullet on nav menu ?
9 years 6 months ago #185537 by baboon
see here :
Thanks !
9 years 6 months ago #185545 by rich
You can try this code in your custom.less docs.kunena.org/en/manual/backend/templates/edit-less
.layout#kunena ul>li::before { display: none; }
9 years 6 months ago #185586 by baboon
Thanks I set as you said, clear the website cache on my cache browser and I have still the bullet displayed, you can see it here :
www.artskorps.org/forum/index.html
9 years 6 months ago #185587 by WolfgangOWL
This is no Kunena problem but an issue with your Joomla template.
In line 187 of the typo.css file
replace
.maincontent ul {
list-style: disc outside none;
with
.maincontent ul {
list-style: none;
9 years 6 months ago #185588 by baboon
Thanks it's ok now :)
9 years 6 months ago #185608 by Stefan
Hi there,
I have the same problem, but I can't find any typo.css file in my template directory.
Any idea?
www.awesomescreenshot.com/image/2505072/...0cf10a7375c2347a2387
