Please Read This First:
Do not use this category for:
Solved Issues After Upgrading from 4 to 5.0.4
9 years 10 months ago - 9 years 10 months ago #182593 by ThePowersThatBe
I just updated from the last 4 version to 5.0.4. On topic pages the buttons are now misaligned and there is an extra blank box after each attachment thumbnail:
If I try to make any changes to the Template settings on the admin side, I get this error (Operation Failed: Failed to write configuration file.):
If I log into the front end with an admin account, the avatar is not displayed:
And I get this "Warning Rename failed." message on every page load.
If I log into the front end with a regular account, the avatar is shown correctly and there is no warning message.
Thanks for reading. Any guidance would be appreciated!
Last edit: 9 years 10 months ago by ThePowersThatBe.
9 years 10 months ago - 9 years 10 months ago #182594 by ThePowersThatBe
I resolved the issues with the configuration file and avatars. When the new version of Kunena installed, the cache and /components/com_kunena folders and files were created with incorrect user permissions. I manually configured the permissions and those errors are fixed.
Under "Templates, Crypsis, Basic Settings" I changed "Load Bootstrap css" to YES and that helped with button icons, however the misalignment problem still persists:
9 years 10 months ago #182620 by rich
Can you post a link please? But we would need also an account (minimum moderator), otherwise we can't see the buttons.
9 years 10 months ago - 9 years 10 months ago #182621 by ThePowersThatBe
It is a private forum, I could message you an account but I cannot post a link. I do not see any way to message you here.
I am using Favourite theme on my site.
demo.favthemes.com/favourite/
The buttons also appear this way at the bottom of each post when logged in to a regular account.
Last edit: 9 years 10 months ago by ThePowersThatBe. Reason: cannot submit new posts with attachments, editor page just reloads instead of posting, I have to submit plain post and then edit post to add attachments here?
9 years 10 months ago #182623 by rich
You can use the confidential tags, then only you and we moderators can see it.
The following user(s) said Thank You: ThePowersThatBe
9 years 10 months ago #182624 by ThePowersThatBe
OK, thank you.
