Please Read This First:
Do not use this category for:
Question Crypsis and Kunena 5.0.3
10 years 1 week ago - 10 years 1 week ago #181786 by joomleb
Hi guys,
I upgraded my Joomla 3.6.4 to Kunena 5.0.3 and selected Crypsis default template.
Now, not all work as expected, so, Please I have a serie of small questions:
1 - the menu bar is more high respecting to the buttons, see my attached image, Why ?!?
2 - How to take over (or hide) the profile menu window
3 - The categories do not have their icons, why ? Are there not the default ones ? If no, how (and which tyoes) can I add them ?
4 - What is that piece of code ? How to erase it ?
PS When I found the solutions, Can I report them into the Kunena - Documentation - Templates ?!?
Many Thanks for help!
Last edit: 10 years 1 week ago by joomleb.
10 years 1 week ago #181787 by 810
Replied by 810 on topic Crypsis and Kunena 5.0.3
1 + 4) are joomla template issues: please add link
2) you can hide the dropdown by css:
.nav.pull-right {display: none;}
3:) empty the "default category icon" option on crypsis
10 years 1 week ago - 10 years 1 week ago #181788 by joomleb
Replied by joomleb on topic Crypsis and Kunena 5.0.3
Hi 810,
1+4 you can see it on this test site and here you can see that the search fied at the top have a colour backgraund while at the bottom do not have that.
2 - thanks, please, in which file ?
3 - Editing Crypsis Template > Basic Settings > Default Icon Set: default - I erased it and saved, but nothing happen and "default" appears againg after saving
10 years 1 week ago #181789 by 810
could you add the kunena report.
backend - kunena - tools - report
10 years 1 week ago - 10 years 1 week ago #181790 by joomleb
Hi 810,
thanks for your support. Sure, here is attached (not anonymous). I also want add two things:
5 - On the menu bar, when I click on any menu that is not the Forum, the Forum one remain as clicked.
Please, how to manage the text / hover / clicked colour ?
6 - On the search page the "Advanced Search" title I suppouse follow my Heading 1 template and "Options search" follow my Heading 2 template. Would not be good to have them with the same "Heading 1" ?
If not, How can I change the "Options search" title, at least to take over the colour background I use for "Heading 2" on my template ?
Let me know if you need anything else
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : aimfi.org | author: eGulp! | version: 1.0.2 | creationdate: 20130613
Kunena default template details : Crypsis | author: Kunena Team | version: 5.0.3 | creationdate: 2016-10-23
Kunena version detailed: Kunena 5.0.3 | 2016-10-23 [ Dibatag ]
Plugins: None
10 years 1 week ago #181791 by 810
2) on backend - kunena - template - edit less - select custom.less
3) you need clear default category icon. Not default icon set
Time to create page: 0.154 seconds
