Please Read This First:
Do not use this category for:
Question Module Position 'kunena_announcement' Not Working
  • thumdar
  • thumdar's Avatar Topic Author
  • Offline
  • Junior Member
  • Junior Member
  • Joomla Web Design at JSYMedia.com
13 years 3 months ago #147735 by thumdar
I can't get the kunena_annoucement module position to appear in my 3.02 template. I have a Custom Content module currently published in that position. Any thoughts?
thumdar.com/forums.html
13 years 3 months ago #147744 by Mortti
"If you are having problems then, for your own benefit, it would save us all a lot of time if you would kindly post your configuration report when you ask for help from this forum. If you do not post your configuration report we will not ask you for it but you will probably not get your problem solved, eith1er."
The following user(s) said Thank You: thumdar
  • thumdar
  • Offline
  • Junior Member
  • Junior Member
13 years 3 months ago #147766 by thumdar
Sorry, I thought I had read that the Configuration Report function ended with the last version. My bad.
htaccess: Exists | PHP environment: Max execution time: 600 seconds | Max execution memory: 1024M | Max file upload: 500M
Joomla default template details : rt_cerulean | author: RocketTheme, LLC | version: 1.1 | creationdate: Unknown
Kunena default template details : Blue Ragle (Responsive) | author: Asika | version: 1.0.0 | creationdate: 2013-06-23
Third-party components: Jomsocial 3.0.1
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
13 years 3 months ago #147780 by sozzled
1) You should contact JomSocial for information about updates to their add-ons for K 3.0.2.
2) We do not know anything about the third party Kunena template (Blue Ragle (Responsive) 1.0.0 by Asika). If this template does not have a kunena_announcement module position, you should discuss this matter with the author of the template you are using.
