Question User sync not working
11 years 4 months ago - 11 years 4 months ago #167204 by oestek
User sync not working was created by oestek
I've searched the forum but have not found an answer to this issue.
We have over 5000 Joomla! users, but when we perform a Kunena user sync, we remain at 173 Kunena users.
Am I misunderstanding the function? I'm assuming we're supposed to have the same number of Kunena users as Joomla! after syncronizing users.
Thanks!
Last edit: 11 years 4 months ago by oestek.
11 years 4 months ago #167205 by oestek
Replied by oestek on topic User sync not working
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 128M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.7 | creationdate: 2015-02-01
Kunena version detailed: Kunena 3.0.7 | 2015-02-01 [ Galah ]
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.7
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1
11 years 4 months ago #167206 by sozzled
Replied by sozzled on topic User sync not working
oestek wrote: Am I misunderstanding the function? I'm assuming we're supposed to have the same number of Kunena users as Joomla! after syncronizing users.
You are correct. Try the procedure shown in the following image:
As you may know , K 3.0.7 is is obsolete and it is not supported. As a suggestion, it might be a good idea to update to K 3.0.8 .
11 years 4 months ago #167207 by oestek
Thanks, I'll upgrade.
I tried that procedure, this is what I received:
Message
0 user profiles have been added
108 user profiles have been removed
0 messages have been updated
11 years 4 months ago #167208 by sozzled
Thanks for your reply. Unfortunately, it looks like there may be a corruption in one of your database tables—the table of Joomla users. I do not know what version of Joomla you are using but, in J! 3.4.3 (the latest version of Joomla), the Joomla users are stored in the table _users
I suspect that one of the records in your _users table may be corrupted and, therefore, may be preventing the Kunena Synchronise Users feature from doing its job.
If you only have "173 users", my guess is that the 174th record may be the "problem" one.
It is not easy for someone like me—I am just an "ordinary" person like you; I am not a member of the Kunena development/support team—to help you via this forum. Perhaps one of the Kunena developers or forum moderators has a better idea and the means to help you here on this forum.
11 years 4 months ago #167209 by oestek
Interesting theory, I'll take a look at the Joomla user table.
Thanks for the idea.
Time to create page: 0.155 seconds
