Question RSS Feed to create threads in Kunena Forum Section
11 years 6 months ago #164629 by Webbrent
Good Day All,
I previously made use of a plugin/module that automatically created topics in my Kunena forum under a predefined threads from a specific RSS XML feed. I am now unable to find the plugin/module that I made use of previously.
My intentions are to have the module/plugin create the topics and then feed the Kunena topics to my Joomla front-end in the form of a "Featured Post slider". Obviously it would need to apply the most recent topic creations to the front page.
Any advice or assistance in the right direction would be highly appreciated.
Thanking you in advance.
11 years 6 months ago #164918 by Webbrent
11 years 6 months ago #164921 by 810
use a rss2content component
then use the kunena discuss plugin.
11 years 6 months ago - 11 years 6 months ago #164933 by sozzled
This is a similar answer given to the same question asked in How to pull a RSS feed from another website to my forum?
There is a component called Rss2Content that was developed for J! 1.5. This component will not work in J! 3.x. There may be another component that you can use to generate Joomla articles from RSS feeds but I have not used any of them and, therefore, I cannot say if any of them are any good. You may find what you are looking for here in the Joomla Extensions Directory .
What is unclear from the answer, about using the Kunena Discuss plugin, is how you can show RSS feeds in your forum. If you have a Joomla article—however the article may be created—then you should be able to "push" its contents into your forum with the Kunena Discuss plugin. I hope this extra information helps better to explain the moderator's reply earlier in this topic.
I realise that the moderators are reluctant to merge together topics that relate to similarly-asked requests for information but this topic and How to pull a RSS feed from another website to my forum? are basically the same question. :)
Last edit: 11 years 6 months ago by sozzled.
