Question COM_KUNENA_
11 years 6 months ago #164562 by antmil
COM_KUNENA_ was created by antmil
For some buttons and some links my forum shows texts COM_KUNENA_ ... (for example, COM_KUNENA_GEN_MARK_ALL_FORUMS_READ). How can I obtain correct labels? Thank You
11 years 6 months ago #164563 by antmil
Replied by antmil on topic COM_KUNENA_
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 50M
Joomla default template details : Cepon | author: ThemeSoul.com | version: 1.17.5 | creationdate: Unknown
Kunena default template details : Cepon | author: Kunena Team | version: 1.0.1 | creationdate: 20 March 2014
Plugins: None
11 years 6 months ago #164566 by 810
Replied by 810 on topic COM_KUNENA_
first try to install the kunena language pack, you can find it on the download page.
11 years 6 months ago #164567 by antmil
I have already installed pkg_kunena_languages_v3.0.8_2015-04-05.zip
11 years 6 months ago #164569 by 810
ok then the language files are missing strings.
There are 3 thing you can do:
1) Load missing strings, This option in the kunena configuration loads also the English language, so when there is a missing strings it takes the English string.
2) Add the missing strings on the language files:
\components\com_kunena\language\it-IT
3) Add missing strings on the language override.
backend - extentions - language manager - overrides - add new strings.
I suggest the first option.
The following user(s) said Thank You: antmil
