Question Merge two posts from the same user, same thread
11 years 6 months ago #164026 by Azmandius
I've used search, there's no solution for this simple task.
All i need is to merge two posts, from same users, same thread, posted one after the other.
How do i do that?
Thanks!
11 years 6 months ago #164112 by rich
I'm not sure whether I have understood the question correctly. You want to change the order of posts? This is unfortunately not possible.
11 years 6 months ago - 11 years 6 months ago #164114 by Azmandius
Yes, you did not understand the question correctly. For example a user has user posted two replies in a row, one after the other, all concerning the same issue, i would like to merge those two replies. Is it possible in Kunena? A s much as i know is it possible in any other regular discussion board script.
Last edit: 11 years 6 months ago by Azmandius.
11 years 6 months ago - 11 years 6 months ago #164115 by sozzled
There is no option in Kunena to "merge two consecutive messages posted by the same user in the same topic". I have not seen this kind of feature used in any web-based discussion forum product anywhere.
However, as a forum moderator you can edit the contents of the first message and include the contents of the second message and then you can delete the second message. It's a bit more fiddly doing it this way but the result is still the same.
I would not imagine that you would have to perform this procedure very often.
I hope that answers your question.
Last edit: 11 years 6 months ago by sozzled.
11 years 6 months ago #164256 by Azmandius
Thank you, that answers my question.
Regards.
