Question After cloning blue_eagle template he still load css from blue_eagle tempalte...
11 years 7 months ago #163347 by BamiGorengo
hey there,
for the first sry for my bad english =)
I read the wiki. i change the values in the xml and in the initialize.php
i change it to "class KunenaTemplateDev_Mafuba extends KunenaTemplate"
my initialize.php
<?php /** * Kunena Component * @package Kunena.Template.Blue_Eagle * * @copyright (C) 2008 - 2015 Kunena Team. All rights reserved. * @license http://www.gnu.org/copyleft/gpl.html GNU/GPL * @link http://www.kunena.org **/ defined( '_JEXEC' ) or die(); // LESS COMPILER require_once(__DIR__.'/less/lessc.inc.php'); $less = new lessc; $less->checkedCompile(__DIR__."/less/style.less", __DIR__."/css/style.css"); class KunenaTemplateDev_Mafuba extends KunenaTemplate { // Try to find missing files from the following parent templates: protected $default = array('dev_mafuba'); protected $css_compile = false; protected $userClasses = array( 'kwho-', 'admin'=>'kwho-admin', 'globalmod'=>'kwho-globalmoderator', 'moderator'=>'kwho-moderator', 'user'=>'kwho-user', 'guest'=>'kwho-guest', 'banned'=>'kwho-banned', 'blocked'=>'kwho-blocked' ); public $categoryIcons = array('kreadforum', 'kunreadforum'); public function initialize() { KunenaFactory::loadLanguage('com_kunena.tpl_blue_eagle'); // Enable legacy mode KunenaTemplateLegacy::load(); require_once JPATH_SITE. '/' . $this->getFile('initialize.php'); $this->addStyleSheet ( 'css/kunena.20.css' ); // Toggler language strings JFactory::getDocument()->addScriptDeclaration('// <![CDATA[ var kunena_toggler_close = "'.JText::_('COM_KUNENA_TOGGLER_COLLAPSE', true).'"; var kunena_toggler_open = "'.JText::_('COM_KUNENA_TOGGLER_EXPAND', true).'"; // ]]>'); } public function getButton($link, $name, $scope, $type, $id = null) { $types = array('communication'=>'comm', 'user'=>'user', 'moderation'=>'mod', 'permanent'=>'mod'); $names = array('unsubscribe'=>'subscribe', 'unfavorite'=>'favorite', 'unsticky'=>'sticky', 'unlock'=>'lock', 'create'=>'newtopic', 'quickreply'=>'reply', 'quote'=>'quote', 'edit'=>'edit', 'permdelete'=>'delete', 'flat'=>'layout-flat', 'threaded'=>'layout-threaded', 'indented'=>'layout-indented', 'list'=>'reply'); $text = JText::_("COM_KUNENA_BUTTON_{$scope}_{$name}"); $title = JText::_("COM_KUNENA_BUTTON_{$scope}_{$name}_LONG"); if ($title == "COM_KUNENA_BUTTON_{$scope}_{$name}_LONG") $title = ''; if ($id) $id = 'id="'.$id.'"'; if (isset($types[$type])) $type = $types[$type]; if ($name == 'quickreply') $type .= ' kqreply'; if (isset($names[$name])) $name = $names[$name]; return <<<HTML <a $id class="kicon-button kbutton{$type} btn-left" href="{$link}" rel="nofollow" title="{$title}"> <span class="{$name}"><span>{$text}</span></span> </a> HTML; } public function getIcon($name, $title='') { return '<span class="kicon '.$name.'" title="'.$title.'"></span>'; } public function getImage($image, $alt='') { return '<img src="'.$this->getImagePath($image).'" alt="'.$alt.'" />'; } }
<?php /** * Kunena Component * @package Kunena.Template.Blue_Eagle * * @copyright (C) 2008 - 2015 Kunena Team. All rights reserved. * @license http://www.gnu.org/copyleft/gpl.html GNU/GPL * @link http://www.kunena.org **/ defined( '_JEXEC' ) or die(); $app = JFactory::getApplication(); $document = JFactory::getDocument(); $template = KunenaFactory::getTemplate(); // Template requires Mootools 1.2 framework $template->loadMootools(); // We load mediaxboxadvanced library only if configuration setting allow it //if ( KunenaFactory::getConfig()->lightbox == 1 ) { // $template->addStyleSheet ( 'css/mediaboxAdv.css'); // $template->addScript( 'js/mediaboxAdv.js' ); //} // New Kunena JS for default template $template->addScript ( 'js/default.js' ); // Dev-Mafubas compiled less file $template->addStyleSheet ( 'css/style.css'); $rtl = JFactory::getLanguage()->isRTL(); $skinner = $template->params->get('enableSkinner', 0); if (file_exists ( JPATH_ROOT . "/templates/{$app->getTemplate()}/css/kunena.forum.css" )) { // Load css from Joomla template CKunenaTools::addStyleSheet ( JUri::root(true). "/templates/{$app->getTemplate()}/css/kunena.forum.css" ); if ($skinner && file_exists ( JPATH_ROOT. "/templates/{$app->getTemplate()}/css/kunena.skinner.css" )){ CKunenaTools::addStyleSheet ( JUri::root(true). "/templates/{$app->getTemplate()}/css/kunena.skinner.css" ); } elseif (!$skinner && file_exists ( JPATH_ROOT. "/templates/{$app->getTemplate()}/css/kunena.default.css" )) { CKunenaTools::addStyleSheet ( JUri::root(true). "/templates/{$app->getTemplate()}/css/kunena.default.css" ); } } else { $loadResponsiveCSS = $template->params->get('loadResponsiveCSS', 1); // Load css from default template $template->addStyleSheet ( 'css/kunena.forum.css' ); if ($loadResponsiveCSS) $template->addStyleSheet ( 'css/kunena.responsive.css' ); if ($skinner) { $template->addStyleSheet ( 'css/kunena.skinner.css' ); } else { $template->addStyleSheet ( 'css/kunena.default.css' ); } } $cssurl = JUri::root(true) . '/components/com_kunena/template/dev_mafuba/css'; ?> <!--[if lte IE 7]> <link rel="stylesheet" href="<?php echo $cssurl; ?>/kunena.forum.ie7.css" type="text/css" /> <![endif]--> <?php $mediaurl = JUri::root(true) . "/components/com_kunena/template/{$template->name}/media"; $styles = <<<EOF /* Kunena Custom CSS */ EOF; $forumHeader = $template->params->get('forumHeadercolor', $skinner ? '' : '#5388B4'); if ($forumHeader) { $styles .= <<<EOF #Kunena div.kblock > div.kheader,#Kunena .kblock div.kheader { background: {$forumHeader} !important; } #Kunena #ktop { border-color: {$forumHeader}; } #Kunena #ktop span.ktoggler { background: {$forumHeader}; } #Kunena #ktab a:hover, #Kunena #ktab li.Kunena-item-active a { background-color: {$forumHeader}; } #Kunena #ktab ul.menu li.active a { background-color: {$forumHeader}; } #Kunena a:link, #Kunena a:visited, #Kunena a:active {color: {$forumHeader};} #Kunena a:focus {outline: none;} #Kunena a:hover {color: #FF0000;} EOF; } $forumLink = $template->params->get('forumLinkcolor', $skinner ? '' : '#5388B4'); if ($forumLink) { $styles .= <<<EOF #Kunena a:link, #Kunena a:visited, #Kunena a:active {color: {$forumLink};} #Kunena a:focus {outline: none;} EOF; } $announcementHeader = $template->params->get('announcementHeadercolor', $skinner ? '' : '#5388B4'); if ($announcementHeader) { $styles .= <<<EOF #Kunena div.kannouncement div.kheader { background: {$announcementHeader} !important; } EOF; } $announcementBox = $template->params->get('announcementBoxbgcolor', $skinner ? '' : '#FFFFFF'); if ($announcementBox) { $styles .= <<<EOF #Kunena div#kannouncement .kanndesc { background: {$announcementBox}; } EOF; } $frontStatsHeader = $template->params->get('frontstatsHeadercolor', $skinner ? '' : '#5388B4'); if ($frontStatsHeader) { $styles .= <<<EOF #Kunena div.kfrontstats div.kheader { background: {$frontStatsHeader} !important; } EOF; } $onlineHeader = $template->params->get('whoisonlineHeadercolor', $skinner ? '' : '#5388B4'); if ($onlineHeader) { $styles .= <<<EOF #Kunena div.kwhoisonline div.kheader { background: {$onlineHeader} !important; } EOF; } $inactiveTab = $template->params->get('inactiveTabcolor', $skinner ? '' : '#737373'); if ($inactiveTab) { $styles .= <<<EOF #Kunena #ktab a { background-color: {$inactiveTab} !important; } EOF; } $activeTab = $template->params->get('activeTabcolor', $skinner ? '' : '#5388B4'); if ($activeTab) { $styles .= <<<EOF #Kunena #ktab ul.menu li.active a,#Kunena #ktab li#current.selected a { background-color: {$activeTab} !important; } EOF; } $hoverTab = $template->params->get('hoverTabcolor', $skinner ? '' : '#5388B4'); if ($hoverTab) { $styles .= <<<EOF #Kunena #ktab a:hover { background-color: {$hoverTab} !important; } EOF; } $topBorder = $template->params->get('topBordercolor', $skinner ? '' : '#5388B4'); if ($topBorder) { $styles .= <<<EOF #Kunena #ktop { border-color: {$topBorder} !important; } EOF; } $inactiveFont = $template->params->get('inactiveFontcolor', $skinner ? '' : '#FFFFFF'); if ($inactiveFont) { $styles .= <<<EOF #Kunena #ktab a span { color: {$inactiveFont} !important; } EOF; } $activeFont = $template->params->get('activeFontcolor', $skinner ? '' : '#FFFFFF'); if ($activeFont) { $styles .= <<<EOF #Kunena #ktab #current a span { color: {$activeFont} !important; } EOF; } $toggleButton = $template->params->get('toggleButtoncolor', $skinner ? '' : '#5388B4'); if ($toggleButton) { $styles .= <<<EOF #Kunena #ktop span.ktoggler { background-color: {$toggleButton} !important; } EOF; } $profileIcons = $template->getFile("media/iconsets/profile/{$template->params->get('profileIconset', 'default')}/default.png", true); $buttonIcons = $template->getFile("media/iconsets/buttons/{$template->params->get('buttonIconset', 'default')}/default.png", true); $editorIcons = $template->getFile("media/iconsets/editor/{$template->params->get('editorIconset', 'default')}/default.png", true); $styles .= <<<EOF #Kunena .kicon-profile { background-image: url("{$profileIcons}"); } #Kunena .kicon-button { background-image: url("{$buttonIcons}") !important; } #Kunena #kbbcode-toolbar li a,#Kunena #kattachments a { background-image:url("{$editorIcons}"); } /* End of Kunena Custom CSS */ EOF; $document->addStyleDeclaration($styles);
I search and replace all the files from blue_eagle to dev_mafuba...
But Kunena still try to load css files from the blue_eagle template...
how can i fix that? and why he does this?
