Solved Default Avatar from JomSocial
11 years 7 months ago - 11 years 7 months ago #163180 by Murnane
Is it possible to have the Kunena forum retrieve a members Jomsocial avatar as default?
Last edit: 11 years 7 months ago by 810.
11 years 7 months ago #163181 by rich
Replied by rich on topic Default Avatar from JomSocial
Go in backend to Kunena-Dashboard and click on the plugin symbol.
Enable the "Kunena - JomSocial Integration" plugin and check if the option "Enable JomSocial Avatars" is set to Yes.
And in the plugin "Kunena - Kunena Integration" you can choose "Enable Kunena Avatars = No".
