Question Missing messages in database
11 years 7 months ago - 11 years 7 months ago #162246 by Tyjeco
Hello, I am trying to move from joomla 2.5 (server 1) to 3.x (server 2). The problem is that after the import of the kunena tables, I am missing the last 40 messages. However... the strange thing is.. they are also missing on server 1! When I check the forum on the frontside, the last message had ID 1654, while when I check in PHPmyAdmin the last ID is 1614, where is the rest? I really have no clue, does Kunena save the last 50 messages or so in a textile?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 25M
Joomla default template details : yoo_cloud | author: YOOtheme | version: 1.0.7 | creationdate: Unknown
Third-party components: Jomsocial 2.4.1
Third-party SEF components: sh404sef 3.6.4.1481 | AceSEF 2.5.4
Plugins: Content - Kunena Discuss 1.7.2 | JomSocial - My Kunena Forum Menu 2.0.1 | JomSocial - My Kunena Forum Posts 2.0.1
Last edit: 11 years 7 months ago by Tyjeco.
11 years 7 months ago #162249 by xillibit
When you look directly on the forum, do-you see that messages are missing ?
11 years 7 months ago - 11 years 7 months ago #162262 by Tyjeco
Replied by Tyjeco on topic Missing messages in database
No, the messages are perfectly visible. I just can't find them in PhpMyAdmin. Even if I search for strings or single words, nothing.... The last 40 messages are nowhere to be found in the Kunena message tables
11 years 7 months ago - 11 years 7 months ago #162268 by rich
Replied by rich on topic Missing messages in database
I see on your phpMyAdmin-image that the numbering is messed up. Choose the sorting by ID. But it seems you have the field "parent" marked on this image.
Last edit: 11 years 7 months ago by rich.
11 years 7 months ago #162271 by Tyjeco
Oops wrong column marked indeed, but the order of the ID column is ok, as you see. After I export and import into Joomla 3 on a different server I still miss those messages.
11 years 7 months ago #162276 by 810
Replied by 810 on topic Missing messages in database
when you copy from the other server, it should be the same. So i can only say, please try again.
Time to create page: 0.157 seconds
