Question Forum alignment
11 years 9 months ago - 11 years 8 months ago #162222 by Bonkn
Forum alignment was created by Bonkn
problem solved
Last edit: 11 years 8 months ago by Bonkn.
11 years 9 months ago #162223 by 810
Replied by 810 on topic Forum alignment
please add url
11 years 9 months ago - 11 years 8 months ago #162224 by Bonkn
Replied by Bonkn on topic Forum alignment
problem solved
11 years 9 months ago #162225 by 810
could you add a screenshot of the issue
11 years 9 months ago - 11 years 9 months ago #162226 by sozzled
Replied by sozzled on topic Forum alignment
Bonkn wrote: Please how do I center align the entire forum?
Generally-speaking, this is a Joomla templating issue. Most quality, commercially-produced Joomla templates should work quite well with most Joomla extensions including Kunena. Therefore, the general answer to the general question starts with the Joomla template that you have chosen for your site. The topic Which came first? The template or the forum? talks about this very general kind of problem.
Bonkn wrote: The site in question is on a local server.
Generally-speaking, it is very difficult to answer questions about template styles and CSS tweaks if your website is on a local, PC-hosted server. The topic Support for PC-hosted websites (e.g. WAMP, XAMPP) discusses some of these aspects of the general approach to website construction, problem diagnosis and resolution.
Although a "screen-shot" (as suggested by 810) may help to understand the kind of problems you seem to be having, it is also quite likely—if I have correctly interpreted your question—that no-one will be able to tell you exactly what you will need to do to resolve your issues while your website is not accessible from the internet.
My recommendation, in cases when people have template styling issues like these on "local servers", is
1) move the site to the internet; or
2) choose a different Joomla template (see My Joomla site template makes a mess of Kunena ...
Good luck :)
Last edit: 11 years 9 months ago by sozzled.
11 years 8 months ago - 11 years 8 months ago #162284 by Bonkn
problem solved.
