Important How to remove Expand/Collapse in templates
11 years 9 months ago #162141 by Bonkn
Hi, Please I am having a little issue with the expand/collapse buttons in the category title bars. Most of my users especially those browsing on mobile often click by accident. It frustrates new users.
My question is, Is there a way to remove the expand/collapse buttons? Or is there a way to make them permanently expand? If so, please where exactly in the templates so I can try on my own?
Thanks very much in advance.
11 years 9 months ago #162169 by rich
You can hide it via css. Add this code at the end of your Joomla! template- or custom.css.
The users, which have currently closed the toggler can open these, but not close again (default is open).
#Kunena a.close { display: none; }
The following user(s) said Thank You: Bonkn
Time to create page: 0.101 seconds
