Solved How to use Kunena as a Support Forum?
11 years 10 months ago - 11 years 10 months ago #161387 by pamkkkkk
Hi All!
I like to use Kunena as a support Forum, to track if an Answer to a question satisfies the questioner.
1.)
Is there a plug-in or build in functionality to mark a discussion post as resolved or unresolved or so?
2.)
Are there different Thread types like Discussion, incident, question or so inside Kunena or as plug in?
greets Peter
Last edit: 11 years 10 months ago by pamkkkkk.
11 years 10 months ago #161388 by sozzled
1) With the standard Kunena package, the moderator and/or topic "owner" (the person who starts the topic) can change the topic icon to a green tick: see K 2.0 Guide to topic icon usage (which also applies to K 3.0)
2) There are no "thread" or topic types as such. You can use different topic icons (as I mentioned in the answer to (1) above) or create different categories of topics.
As far as I know, there are no plugins that are available that will do this but if you look around in the JED you may find something. JED . I hope some of this helps and god luck.
The following user(s) said Thank You: pamkkkkk
11 years 10 months ago #161390 by sozzled
According to the reference posted by 810, this "free" plugin is incompatible with K 3.0.
